Old 01-10-2007, 09:37 PM   #1
ahspride2003
ahspride2003 is on a distinguished road
Default Gear 3 Ratio Incorrect?
What the heck does that mean?! I have a 2001 Saturn SL1, only 54k miles, and my "Service Engine Soon" light came on tonight. It's an automatic, I noticed it wasn't shifting properly and was jerking. I took it to AutoZone and "Gear 3 Ratio Incorrect" is what came up. I had just taken a trip to Michigan yesterday, and it was fine. I have to go to Michigan again on Monday and need it to be fixed by then. I was told that they have to take the whole transmission out. About how much will this whole procedure cost? Thanks for the help!
Add to ahspride2003's Reputation
Rate the quality of this post and help ahspride2003 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ahspride2003 is offline   Reply With Quote
Old 01-10-2007, 09:47 PM   #2
harsha
harsha is on a distinguished road
harsha's Avatar
2006
Default Re: Gear 3 Ratio Incorrect?
By any chance do you remember the "actual Code?"
Is it one of those tranny sensors??
Add to harsha's Reputation
Rate the quality of this post and help harsha reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
harsha is offline   Reply With Quote
Old 01-10-2007, 09:53 PM   #3
ahspride2003
I'm not sure. He didn't give me the code, just told me what was wrong with it.
Old 01-10-2007, 09:53 PM   #4
eRic 02sc2
eRic 02sc2's Avatar
what's the P#### code?
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
Old 01-10-2007, 09:55 PM   #5
ahspride2003
He didn't give me a code. I'm taking it in tomorrow. As long as it's under 600 I'm fine.
Old 01-10-2007, 09:56 PM   #6
eljefino
eljefino's Avatar
1995 SW1
I would borrow someone elses car, or rent one, for this MI trip. Hard to diagnose and fix something now and have complete confidence by monday.
Simple stuff you can check is fluid level and alternator output... listen to AM radio with the rear defogger and lights on... for a whine that varies with engine speed. See if ~14 volts is present with the car running.
This is a serious issue, as 3rd gear is slipping or not engaging properly... could be a solenoid in the valve body or the valve body itself... not as bad as a whole transmission but not trivial either. May be worth a pro diagnostics and not one by a guy who's first words out of his mouth are "you need a new transmission".
If you go to the how-to section of this site, search for OBD-II trouble codes by user wolfman. Get the POxxx code (backwards-- use the 3rd gear ratio malfunction for inspiration), remember that, then search this site and google with that code number for some probable causes.
Add to eljefino's Reputation
P0734 - Incorrect 4th Gear Ratio Qjinx S-Series Tech 9 04-22-2009 06:01 AM
1999 SL2 P0731 Gear 1 Incorrect Ratio Problem EdHasA99 S-Series Tech 20 05-28-2008 02:02 AM
Incorrect gear ratio problem-not resolved vectad S-Series Tech 7 08-06-2007 01:21 PM
Incorrect 3rd Gear Ratio code problem katy S-Series Tech 11 05-29-2005 11:23 AM
m/t gear ratio anti honda S-Series Tech 13 08-18-2004 01:58 PM
