Old 11-11-2005, 09:20 PM   #1
RobertGary1
Default Radiator fan coming on late 96 SC2
My fan seems to be taknig too long to come on. Sometimes the gauge is almost in the red before it comes on. I don't think its the ECTS because the gauge would also be indicating low (right??). What other logic does the PCM take into account when deciding when to turn on the fan?
_Robert, 96 SC2
Old 11-11-2005, 09:24 PM   #2
wolfman
wolfman's Avatar
Default Re: Radiator fan coming on late 96 SC2
That's it. Keep in mind the gauge is far from a presision instrument. The fan on a 96' should come on over the 3/4 mark but below the RED hot line and go back off at or just below the 1/2 point on the gauge. If the fan is self actuating and you have no driveability, MPG or cold start issues, leave well enough alone.
Add to wolfman's Reputation
Old 11-12-2005, 12:32 AM   #3
On the 96 the gauge gets the reading from the same sensor that may be sending the wrong reading to the PCM for the cooling fan. The only data that the PCM uses to turn the cooling fan on (for engine cooling, not AC) is the temp reading from the temp sensor.
Add to ssicarman's Reputation
Old 01-10-2012, 03:01 PM   #4
Puck head
Puck head is on a distinguished road
Responding to your don't use oil additives. Ive. Even using Roslone ring seal/stop smoke for about 10k miles now and I'm happy w the results so far. Much less oil burning. I did use another brand b4 barbdal? It didnt wrk. But the Roslone worked great. I went from using a qt every week to a qt evry month. Alot less smoke too. It does still smoke when I take the rpm up to 4 but it stops after 4 rpm. And about u not liking products u have to reuse. What about oil? Ask Saturn why we keep the oil industry wealthy! I hate buying oil and. He king it all the time. I have a 99 Sierra w 215k use nothing but Mobil1 and filter. Doesn't leak or burn oil. Shows where they put there money. Solid truck
Add to Puck head's Reputation
Rate the quality of this post and help Puck head reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Puck head is offline   Reply With Quote
95 sc2 Radiator leak, no freon, cooling fan not running all at once dacchef S-Series Tech 6 09-06-2008 03:55 PM
2001 sc2 radiator fan operation saturnsctwo S-Series General 4 05-11-2007 11:27 PM
late fan drizzlemiao S-Series General 4 03-28-2005 08:44 PM
Radiator fan not coming on 1993 meseville S-Series Tech 6 08-21-2003 09:06 PM
Radiator fan not coming on... Actaeon S-Series Tech 13 07-29-2003 10:15 PM
