Old 10-15-2017, 02:51 PM   #1
xxZombifiedxx
xxZombifiedxx is on a distinguished road
Default my sl2 acceleration is badd!!
Hey guys. I saw a lot of people posting here with questions so decided to see what the experts here have to say about my car.
I've had a 99 Saturn SL2 with 133k miles that recently started having problems when accelerating. It feels like the car is struggling a bit to get up to speed and its' worse uphills.
I changed my spark plugs before getting a code p0140 which is O2 Sensor Circuit No Activity Detected Bank 1 Sensor 2.
My question is, can an O2 sensor cause this performance issue.
I used a scan tool and noticed that sensor 2 stays around 0.445.
I also have some rattling noise sometimes so I wasn't sure how do I test if this is the O2 sensor or my catalytic converter.
Any help is appreciated!
Add to xxZombifiedxx's Reputation
Rate the quality of this post and help xxZombifiedxx reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
xxZombifiedxx is offline   Reply With Quote
Old 10-15-2017, 04:36 PM   #2
toggenburg
toggenburg's Avatar
Default Re: my sl2 acceleration is badd!!
plugged cat can do this.
are you in a state that inspects the exhaust system and might know if you gutted or removed the cat?
As far as the O2, you can remove it and drive a little with it out and see if there is an immediate boost in power (there sure will be a boost in NOISE!).
Old 10-15-2017, 05:24 PM   #3
1-Was the original coolant sensor replaced (temperature gauge needle hovering over the 1/4 mark?). Original round nosed plastic ones crack, flat nosed brass one corrects this problem. You may have to replace the thermostat when the rubber seal melts from the faulty sensor.
2-Downstream O2 sensor output are always steady values to reflect catcon efficiency. If the catcon disintegrated (rattling), cat guts may block exhaust flow. Removing the upstream O2 sensor as suggested and driving will either show a definite increase in engine power or remain the same.
The downstream O2 sensor checks catcon efficiency. The upstream or precat O2 sensor is the important one as its used to help with the EFI/emissions control systems.
Old 10-16-2017, 07:26 AM   #4
If you are pulling the upstream O2, either keep the drive brief or rig up something to block the hot exhaust from melting rubber/plastic in front of it.
ECTS and its connector is a good first place to start. There's still a few cars where this has not been replaced.
Old 10-19-2017, 03:55 PM   #5
Budsaturn
Budsaturn has a spectacular aura aboutBudsaturn has a spectacular aura aboutBudsaturn has a spectacular aura about
1995 SL
Had the same problem with a 95. It was the TPS. Then to make it worse I
bought one on line that was just as bad. Had the local Chevrolet dealer order
me one from GM. It worked perfect at once.
Add to Budsaturn's Reputation
Rate the quality of this post and help Budsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Budsaturn is offline   Reply With Quote
A/C and Acceleration auralsphere S-Series General 5 05-21-2009 08:20 AM
No acceleration Onion S-Series Tech 4 12-07-2008 08:39 PM
'04 vrs '06 RL acceleration Rob Leigh Vue Red Line 15 03-01-2007 05:51 PM
acceleration gaums Mods and Performance 3 07-23-2005 12:35 PM
Acceleration! SLeepr Mods and Performance 9 12-23-2003 08:57 PM
