Old 02-15-2003, 02:06 PM   #1
mkosem
mkosem is on a distinguished road
Default SAFC on TBI SOHC engines
ok, I'm curious about whether or not an APEXi SAFC would work on a SOHC satty. It seems like it just interfaces with the OBD system which would lead me to believe it would be no problem. Has anyone done this? I know that unit has been installed on OBDI sattys before with good results but this situation is a little different.
--Matt
Add to mkosem's Reputation
Rate the quality of this post and help mkosem reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mkosem is offline
Old 02-15-2003, 07:43 PM   #2
Abe95SC2
Abe95SC2 is on a distinguished road
Abe95SC2's Avatar
Default
The real question is why bother doing it for 3-5HP when for 2x the price you can gain 39HP by swapping in a DOHC.
Abe.
Add to Abe95SC2's Reputation
Rate the quality of this post and help Abe95SC2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Abe95SC2 is offline
Old 02-16-2003, 01:40 AM   #3
mkosem
Default
how could I swap in a DOHC for $600? I'd need a speedo, engine, pcm, etc.
--Matt
mkosem is offline
Old 02-16-2003, 01:54 AM   #4
amazinghl
Default
It's call "JUNKYARD"!!!
94 855 394xxx miles
00 Insight 72mpg
Add to amazinghl's Reputation
amazinghl is offline
Old 02-17-2003, 10:26 AM   #5
eRic 02sc2
eRic 02sc2's Avatar
Default
or a coat hanger, late at night...
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 02-18-2003, 09:01 AM   #6
sps SOHC
sps SOHC is on a distinguished road
sps SOHC's Avatar
Default
eric eric eric....I'm disappointed in you...a coat hanger???
Anyways, mkosem, you can do a HEAD swap. But that all depends on the year of your SOHC. I don't know what all is possible but on my 95, it's quite simple. Just get a DOHC head, timing chain and cover, cam cover, and the PCM and you'll be set! Of course you'll have a lower compression and you won't gain 39 hp like Abe is saying, but anyways, you could put JE pistons and then a turbo, or just stock DOHC pistons if you wanted higher compression. But I think that it would be much cheaper than trying to get the whole engine and everything. Unless of course you find a sweet deal on e-bay. Oh wait, you'd have to pay shipping, nevermind!
-96 SC2 gets 35 mpg mix city/hw.
Add to sps SOHC's Reputation
Rate the quality of this post and help sps SOHC reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sps SOHC is offline
Old 02-18-2003, 09:15 AM   #7
eRic 02sc2
eRic 02sc2's Avatar
Default
ok use a slimjim instead. not that I have one or anything like that.
eRic 02sc2
Old 02-24-2003, 02:02 AM   #8
EzDi
EzDi is on a distinguished road
EzDi's Avatar
Default
I'm currently in the process of a head swap. I'd reccomend not doing it and swaping your engine unless you really want to get to know your car/how cars work or you want lower compression pistons on the cheap. I have a '94 and so far I've spent 15 hours and some good knuckle skin + random gaskets. You may be able to get it done in less if you have better luck with your junkyard than I did.
EzDi
Add to EzDi's Reputation
Rate the quality of this post and help EzDi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
EzDi is offline
Old 02-26-2003, 09:45 AM   #9
Garland
Garland is on a distinguished road
Garland's Avatar
Default
You wouldn't BELIEVE how much power is locked up in a SOHC with a bad air fuel ratio. Let me cite an example.
I'm running a custom cam in my car. The cam will be marketed very shortly, so if you really are interested don't ask me questions, just keep an eye open. Anywho ... said cam produced
a peak gain of 2 hp over the same car without a cam, and produced like 8 hp at redline. I had like some reasonable low end loss, it was acceptable to me but it was still like 4.5-6 lb/ft of torque.
So we put an S-afc on after seeing the other test car totally crap out presumably due to AF .. the guy actually lost HP vs non cammed - the hp loss happened EXACTLY where the a/f took a nose dive. So I picked up my S-AFC that was rotting in my room, and installed it in the saturn. Then I took it to the dyno and had them tune/test it. After a mere 7 runs we had it completely tuned. 40 minutes - Thanks kauffman motorsports
Anyways..
End result was the same cam, in the same car, with just TUNING eliminated all low end loss, created a gain from 3k to redline, and a maximum gain of 20 hp (with 6 hp peak gain) vs non cammed.
So what I really wonder is how bad REALLY is the stock saturn computer, and how much power does it lose due to improper a/f ratios at WOT? Either way an s-afc is a great investment if you're doing mods. It can really unlock the hidden horses with an hours worth of dyno time with the right people.
Add to Garland's Reputation
Rate the quality of this post and help Garland reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Garland is offline
Old 02-26-2003, 11:52 AM   #10
Abe95SC2
Abe95SC2's Avatar
Default
Mike are those crank figures or RWHP figures?
Also you might note that the engine in question here is a TBI SOHC. If I remember correctly your car has a MPFI SOHC.
Abe.
Abe95SC2 is offline
Old 02-26-2003, 11:59 AM   #11
Garland
Garland's Avatar
Default
Very true. I was simply citing an example. That 20 hp was at the wheels.
:-D
Anyways.. the TBI model IMHO has more of a reason to be tuned due to it's even cruder fuel control than an MPFI saturn such as mine.
Garland is offline
Old 02-26-2003, 12:51 PM   #12
Abe95SC2
Abe95SC2's Avatar
Default
:-D
Very nice! 20 RWHP is nothing to sneeze at.
You know, now that I think about it My hopped up DOHC has more power at ~90% throttle than at 100% (closed loop vs. open loop I presume). This is so evident that I have contemplated making a throttle stop.
Maybe when the ins. co. finally settles with me and I get another car I'll hook up an AFC/e-manage so I can trim the injectors a bit at WOT.
Abe.
Abe95SC2 is offline
Old 02-26-2003, 01:06 PM   #13
Garland
Garland's Avatar
Default
actually in the coming weeks what I'm going to do is make a fuzzy logic air fuel regulator. What it's going to do is tap into the map, TPS and o2 signals .. use them as input. At less than 85% throttle, nothing will happen. As soon as you go WOT, it will keep you at an optimal fuel trim by adjusting the map signal and tricking the ecu much like the S-AFC .. only this one is not user controlled. There *MAY* be a fine tuning knob on it.. but maybe not. At current time it appears that I will be able to retail it at about 100 dollars a unit. It will be specifically for saturns.
That's all the data I can give right now.
Garland is offline
Old 02-26-2003, 01:09 PM   #14
Garland
Garland's Avatar
Default
Darn right. Check it out:
Garland is offline
Old 02-26-2003, 11:08 PM   #15
mkosem
Default
hmm
--Matt
mkosem is offline
Old 02-26-2003, 11:19 PM   #16
EzDi
EzDi's Avatar
Default
I don't think you would see such a difference without the breathing mods. The stock computer can't understand the airflow curve of a modified engine when in open loop, it's programmed for a stock engine. When you add mods, it doesn't know, but the O2 sensor tells it how much fuel it needs in closed loop, making it run nice, but when you go to open loop, it'll run lean because it thinks there isn't as much air as there really is.
The TBI's poor performance is not due just to it's single injector, it has more to do with the throttle being smaller and having an injector in front blocking the airflow.
With the mpfi using batch fire, the only thing you might get is beter atomization, but I think that might not be so much of an issue because the fuel has longer to mix in a TBI setup.
EzDi
EzDi is offline
Old 02-27-2003, 07:10 AM   #17
Garland
Garland's Avatar
Default
I'm not even sure it can understand proper a/f delivery even with a bone stock car. I know the SOHC pcm at 3800 rpm switches to a 12.4:1 a/f ratio in it's fuel map. This is programmed in. It's amazing how mild changes in a/f so greatly affect this car. And really 12.4:1 isn't exactly maximum power. Best power will be found from 13:1-12.7:1 or .86-.91v on the o2 sensor feed. So it's already off from the factory in terms of power gain. Sure, the gain won't be as great as with modifications but given my own personal experience with the saturn pcm I am very willing to bet that there are several horses locked up in a poorly managed a/f ratio.
Garland is offline
Old 02-27-2003, 08:04 AM   #18
mkosem
Default
Well, I'm planning on getting Fonzo's intake when his family problems correct themselves. He is holding one for me. That intake has a 50mm TB on it. I also have a CAI that I'll put on around the same time. In addition to that, I have a DynoMax SuperTurbo muffler which made a very noticible difference. I hope to be doing prety well after the intake stuff get's here and on.
--Matt
mkosem is offline
Old 02-27-2003, 08:40 AM   #19
Garland
Garland's Avatar
Default
Fonzo's got ALOT of smart mods for the TBI guys. Personally being a SOHC'er myself, I've always been disappointed when I see the lack of availability of mods. I mean it's always Intake, Exhaust, Pulleys, upgrade to dohc...
TBI Guys are just flat out told "Don't even mod it" despite the fact the only thing keeping them from that elusive 15 hp is better a/f management. The internals of the engine are the same between TBI and MPFI/SPFI .. the only difference is a/f management. Yet the better a/f control of the MPFI/SPFI engines yields another 15 hp. Really there is no reason a TBI couldn't make 100 crank hp with better a/f management. Fonzo is really helping the TBI guys out by providing the option of better airflow, which is definately at least half of the equation. The other half would be solved by third party black boxing of the ecu for better fuel control (ala S-AFC).
Good luck mkosem... keep an eye out, we're working to really provide the SOHC market a whole breadth of options to really increase power and make it a more viable platform without having to worry about the amount of time and money that needs to be invested in a head swap.
Garland is offline
Old 03-17-2003, 04:59 PM   #20
spin433
spin433 is on a distinguished road
spin433's Avatar
Default
So what up with my SL1 94- I dont no which sohc engine I have. tks.
And y'all are abbreviation happy. Can you help me out.
Add to spin433's Reputation
Rate the quality of this post and help spin433 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
spin433 is offline
Removing 94 SL1 SOHC TBI MikesterH S-Series Tech 16 07-30-2009 11:41 PM
NA SOHC w/SAFC-II for increased mpg? charcoal S-Series Mods 10 04-28-2006 12:49 PM
DOHC TB on a TBi SOHC??? freakerz Miscellaneous Tech 4 05-23-2004 02:25 PM
1.9L SOHC TBI Injector Aldiaz2331 Miscellaneous Tech 6 03-08-2004 07:24 AM
upgrade 1991 SOHC TBI to 1995 SOHC MPFI tcotrel Mods and Performance 6 06-06-2002 10:51 AM
