Old 06-29-2007, 12:19 PM   #1
Frank91
Frank91 is on a distinguished road
Default Engine fan only turns on when AC is on ?
Question I have a 1991 SL1 4cyl the engine fan only turns on if the AC is on.
On hot days I have to click the AC off and On to make the engine fan run any idea what is the problem I checked all the fuses under the dash all are good not sure if it is a wiring problem or not and if so where should i look.
Any help would be good Thanks.
Add to Frank91's Reputation
Rate the quality of this post and help Frank91 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Frank91 is offline   Reply With Quote
Old 06-29-2007, 12:26 PM   #2
bobc455
bobc455 will become famous soon enough
Default Re: Engine fan only turns on when AC is on ?
How hot have you had the engine? Has it boiled over without the fan ever coming on?
If the engine is not "too" hot, the fan doesn't kick on. It is not on all the time, only when it needs it.
(The A/C requires a fan when, so when you turn on the A/C the fan runs regardless of engine temp)
-BC
Add to bobc455's Reputation
Rate the quality of this post and help bobc455 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bobc455 is offline   Reply With Quote
Old 06-29-2007, 12:32 PM   #3
Frank91
Hello Bob thanks for the reply I have let the temp get almost to the red to see if it would turn on and it never did.
I have had the car for about 3yrs and never saw the engine fan come on unless I turn the AC on and off.
Old 06-29-2007, 12:47 PM   #4
Prime suspect: ECTS. Visit our How-To Library; the first couple of "Sticky" threads describe how/why it fails, how to replace it. It's a one-off fix.
Add to madpogue's Reputation
Old 06-29-2007, 01:11 PM   #5
Frank91
thanks I'll check that out.
Old 06-29-2007, 01:22 PM   #6
Frank91
Yea that might be it because the temp gauge works fine just the engine fan will not come on the temp could be in the red very hot and still no fan only comes on if I turn the AC on and off.
Old 06-30-2007, 04:43 AM   #7
stevestar99
stevestar99 will become famous soon enoughstevestar99 will become famous soon enough
Even if the ECTS is good, the fan won't come on until it hits the RED. It's some where around 220 degrees. A lot of guys have put in a manual by-pass fan switch, so they don't have to run the AC to cool down the engine when they're stuck in traffic,
Add to stevestar99's Reputation
Rate the quality of this post and help stevestar99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
stevestar99 is offline   Reply With Quote
Old 06-30-2007, 04:46 AM   #8
SaturnManiac
SaturnManiac's Avatar
It comes on before red, just not much before red...and that's only on the older S-Series. 1995 and older were like that, in 1996 and above, Saturn made it so the fan came on sooner.
But, I'd look into the ECTS, because chances are you probably still have the plastic-tipped one in there regardless. You want to replace it with a brass-tipped one from the Saturn retailer.
Add to SaturnManiac's Reputation
Rate the quality of this post and help SaturnManiac reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 06-30-2007, 08:04 AM   #9
RickKlages
RickKlages is on a distinguished road
RickKlages's Avatar
ECTS = Excellent Corrective Tonic for Saturn. How one little cheap part can cause so many headaches!
All Saturn owners begin the mantra:
ECTS
ECTS
ECTS
ETCS
ad infinitum
ick
Add to RickKlages's Reputation
Rate the quality of this post and help RickKlages reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RickKlages is offline   Reply With Quote
Engine fan only turns on when AC is on ? Frank91 L-Series General 2 06-29-2007 12:16 PM
95 sl2 rad fan turns on once in a while projectpete19 S-Series Tech 25 05-30-2007 12:17 PM
A/C Fan Turns On When Car Is OFF ??? SafariMelissa S-Series Tech 2 07-22-2006 09:33 PM
Fan turns on too late dmacias666 S-Series Tech 13 03-07-2006 10:30 AM
Cooling Fan Turns on when engine is cold. 95sl2inHB S-Series Tech 8 07-10-2005 12:15 AM
