Old 03-12-2019, 09:22 PM   #1
tewin777
tewin777 is on a distinguished road
Default Key Fob
Dumb question all. My Saturn Vue will no longer unlock with Fob but Lock works fine. 2005 - 2.2 L 4 Banger. i tried the old cover in case it was the switch again. also tried new batteries. Thanks in advance. Also note i have a new battery i bought just before freezinggedon. -28 F, MN.
Add to tewin777's Reputation
Rate the quality of this post and help tewin777 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
tewin777 is offline   Reply With Quote
Old 03-12-2019, 10:29 PM   #2
atikovi
Default Re: Key Fob
Bad remote? Some parts stores have testers or you can buy one for $50.
Add to atikovi's Reputation
Old 03-12-2019, 11:24 PM   #3
far2grumpy
far2grumpy's Avatar
Default Re: Key Fob
You could try RKE - BCM resync ... see thumbnail
Old 03-13-2019, 08:54 AM   #4
tewin777
Default Re: Key Fob
Thanks, to all.
Apparently a FOB issue. Tried to resync and never clicks the latches.
Peace, Love and Wiener Dogs.
BTW Scottie Kilmer Loves my 2.2 L Ecotech, Not.
Brian M. Babey
Old 03-21-2019, 09:38 AM   #5
tewin777
Default Re: Key Fob
Not to be a Columbo, Pardon me people can i ask one more question? Is there any info on the vehicle itself to find out what frequency code i should look for in a FOB? i bought 2 fobs that dont work only to find out they will on 3 liter and not the 2.2 liter Saturn? Thanks.
Old 03-21-2019, 10:00 AM   #6
RobertGary1
1996 SC2
Default Re: Key Fob
I donít think any Saturn can be user programmable. Youíd need someone with a tech2 to program it.
-Robert
RobertGary1 is online now   Reply With Quote
Old 03-21-2019, 10:14 AM   #7
atikovi
Default Re: Key Fob
Program Saturn Vue remotes (works on 2006)
Up to 4 remotes may be programmed.
All remotes should be programmed at the same time as existing codes will be erased.
1. Close doors.
2. Insert key, do not turn.
3. Press and hold door lock switch in the unlock position on the door).
4. Switch ignition on, off, on, off.
5. Release door lock switch.
6. Doors should lock and unlock one time to confirm programming mode. (This did not happen so just continue to step 7)
7. Simultaneously press and hold the LOCK and UNLOCK buttons of the first remote transmitter for 15 seconds.
8. Doors should lock and unlock to confirm programming of the first remote transmitter.
9. Repeat steps 7 and 8 for all remaining transmitters.
10. Switch ignition ON to exit programming mode. (Didnít do this, just pulled out the key)
Old 03-21-2019, 10:26 AM   #8
tewin777
Default Re: Key Fob
Thanks, All. Will this method when i get home. As Ace Hardware told me that only after 2008 are encrypted and needs them to program. Otherwise mine is identified as EZ config.
Old 03-25-2019, 04:45 PM   #9
tewin777
Default Re: Key Fob
Got a replacements fob but it appears they dont work. is it true that Vue 2005 had 2 different keyless entry based upon engine size? the remotes i got are for the 6 banger? i assume i need to go by FCC id? Since my car didnt come with original remotes i have no id of correct fcc id. Any info would be appreciated.
Old 03-26-2019, 06:03 PM   #10
RobertGary1
1996 SC2
Default Re: Key Fob
I would be very surprised if you could program a new fob without a Tech II. I've never seen a fob seller claim otherwise.
-Robert
Old 03-26-2019, 07:31 PM   #11
atikovi
Default Re: Key Fob
Programmed these flip keys to my 06 a few months ago using the instructions posted.
Old 03-27-2019, 12:17 AM   #12
craftsman70
craftsman70 is on a distinguished road
2000 SL1
1998 SL1
Default Re: Key Fob
I like those flip keys, where did you get them? How did you know that they'd work? That is, is there a certain type or specification you look for?
Add to craftsman70's Reputation
Rate the quality of this post and help craftsman70 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
craftsman70 is offline   Reply With Quote
Old 03-27-2019, 12:26 AM   #13
atikovi
Default Re: Key Fob
I got them on Ebay for a GMC Yukon if I recall, can't remember exactly now. Seller in China. Did have to lengthen the slot in the blade with a Dremel to make it fit.
