Old 01-29-2008, 11:00 PM   #1
hufhouse
hufhouse will become famous soon enough
2002 L-Series 3.0L Sedan
2001 SL2
Default p0421 - WARM UP CATALYST LOW EFFICIENCY BANK 1
Got this code today. Cleared it, but I'm worried it's going to come back.
I had the "main" catalytic converter under the car replaced last week with one from Magnaflow.
Now, the "Bank 1" (by the firewall) warm-up catalyst is supposedly not doing its job.
Unfortunately, it doesn't appear that this little warmup catalyst is available by itself. It's part of a whole piece that include the rear half of the front pipe AND the catalytic converter I replaced last week.
I can't find anyplace that sells just the warmup catalyst.
No misfires. Well, I had misfires when the converter went totally bad, but none before or since.
My gut feel is that it might have to do with the high-flow replacement catalytic converter.
I don't think there's any kind of exhaust leak or I would hear it.
Anyone got any ideas?
Add to hufhouse's Reputation
Rate the quality of this post and help hufhouse reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hufhouse is offline   Reply With Quote
Old 02-20-2008, 12:57 PM   #2
hufhouse
2001 SL2
Default Re: p0421 - WARM UP CATALYST LOW EFFICIENCY BANK 1
I continued to get this code about once every 7-8 days. I ignored it the first couple of times, thinking it might be a "carryover" from all of the misfires and driveability issues surrounding the catalytic converter failure.
Anyway, I took it back to the shop that did the catalytic converter and asked them to see if they could figure out why I was getting the code and make sure there wasn't any kind of leak.
They tested everything and found that Bank 1 Sensor 2 was sending voltage "all over the map." So, they are replacing the sensor.
Hopefully, this will fix the problem.
Just thought I would throw an update out there in case anyone can use the info in the future.
Old 08-18-2014, 11:21 PM   #3
Mehdi
Mehdi is on a distinguished road
2004 L-Series 3.0L Sedan
Did finally fix it?
Add to Mehdi's Reputation
Rate the quality of this post and help Mehdi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mehdi is offline   Reply With Quote
DTC P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1 ivymotorsports S-Series Tech 1 04-26-2009 01:29 AM
Low idle when warm/hot. KeithR S-Series General 4 11-09-2008 11:01 PM
94 sl1 runs rough at low speeds when warm compo1 S-Series Tech 2 09-29-2006 11:58 PM
Trans wont shift out of low warm gbic1 S-Series General 0 02-07-2005 12:57 AM
P0420 Catalyst System Low Efficiency xcfmx S-Series Tech 7 01-12-2005 04:34 AM
