Old 08-02-2013, 01:33 AM   #1
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default Brake Drum Self Adjuster....
Replaced my brake drums on the rear today. Loud noisy grinding sounds, now gone...
In order to make them fit, I needed to turn the self adjuster.
Most of the teeth on the self adjuster were chipped / broken...
Are these necessary? Should I replace the self adjuster?
Also to tighten the brake shoes (move closer together) go from the brake cylinder down when looking at the front of the brake assembly....
2002 Silver SL2, manual, 5th gear swap (.605), 79,900 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 08-02-2013, 06:44 AM   #2
Default Re: Brake Drum Self Adjuster....
A proper drum brake system overhaul requires removing everything from the backing plate and cleaning and correctly repainting the backing plate. Then all parts are replaced with new, including the drum. Any less than that usually leads to a less than satisfactory experience.
rear drum removal - adjuster access hole LastL4Banger Vue Tech 20 04-16-2012 06:33 AM
drum adjuster lock tab fetchitfido S-Series Tech 1 04-19-2011 02:50 PM
Rear brake adjuster question bryanb S-Series Tech 22 03-05-2011 04:39 PM
How to loosen a rear drum brake adjuster on a 92 saturn SC Nicholai_Volkov S-Series Tech 4 12-03-2010 12:07 AM
94 sl2 rear brake adjuster mrfox11705 S-Series General 2 08-17-2005 11:37 PM
