Old 11-30-2008, 01:14 PM   #9
Melissa_M
Melissa_M has a spectacular aura aboutMelissa_M has a spectacular aura aboutMelissa_M has a spectacular aura about
Default Re: Upper motor mount replacement made easier with pictures
Originally Posted by bobbyrae View Post
This thing about jacking on the oil pan is completely unnecessary. The SSM suggests that you place a 3/4" piece of wood under that lower strut (that Richpin retightens). This holds the engine in place while replacing the upper mount. I've done it this way and found it so much easier and quicker.
Thanks for all the photos!
So with the wood block under the dogbone, you don't need to jack it up at all?
Melissa_M
1999 SL2 MANUAL ~76K
Add to Melissa_M's Reputation
Rate the quality of this post and help Melissa_M reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Melissa_M is offline   Reply With Quote
