Old 03-01-2006, 12:02 PM   #10
sl2collector
sl2collector is on a distinguished road
Default Re: Fan turns on too late
IMO, If you fan was running all the time until then, it prolly never been up to proper operating temp, and it is very likely you coolant system is just slighly overfilled, and when normal temp is reached, there is enough in the system to overflow, is it at the cold line when cold?or over or under the line?
Add to sl2collector's Reputation
Rate the quality of this post and help sl2collector reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sl2collector is offline   Reply With Quote
