Old 05-26-2019, 02:47 PM   #19
oldwood
oldwood is on a distinguished road
Default Re: Changing the serpentine belt on the Ecotec
I just did my 2005 Vue 2.2. I took the air filter box off (1 bolt and the clamp) Then I could clearly see the 3/8 socket location. I had a old 3/8 breaker bar and was able to get it into the socket with no problem. The breaker bar has a hole in the end so I inserted a wrap tie through the motor lift bracket and the hole in the end of the breaker bar. Then I just pulled up on the bar and pulled the wrap tie tight.
The old belt slipped off without a problem. Putting the new one on was a fiddle but with the tension-er out of the way it was not a problem. Once the new belt was in place I just cut the wrap tie with a pair of side cutters. (good to have your other hand in your back pocket when cutting the wrap tie ) I did all of the install from the tops side.
Thanks to everyone who posted pictures and instructions!! Made the job pretty easy.
I should have taken pictures but I always remember that when I close the hood.
Add to oldwood's Reputation
Rate the quality of this post and help oldwood reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
oldwood is offline   Reply With Quote
