Old 09-01-2007, 11:12 AM   #3
David 93 SL2m
David 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the roughDavid 93 SL2m is a jewel in the rough
David 93 SL2m's Avatar
2004 VUE 2.2L
2007 ION-3 Sedan
Happy Re: Changing the serpentine belt on the Ecotec
Originally Posted by Bigdaddy94sc2 View Post
It is really pretty easy. It goes in an oblong circle, with the tensioner holding force in the downward direction. There are only 3 pulleys it goes around.... Just make sure to look at it before you take it off. Use a 3/8" drive ratchet to relieve tension on the tensioner, and you are off!
IIRC, there is a diagram in the owners manual.
You are right, the diagram is in the owner's manual. Here is a scan of the diagram from my 2004 VUE owner's manual. It is sort of hidden. It was toward the back on page 6-17 just a few pages before the index.
Current
∙ 2004 VUE 124K
∙ 2007 ION3 112K
Past
∙ 1993 SL2 212K
∙ 1993 SC2 140K
∙ 1996 SC2 157K
∙ 1996 SC2 126K
∙ 2001 SC2, 145K
∙ 2002 L200 20K
∙ 2002 SL1 129K
Add to David 93 SL2m's Reputation
Rate the quality of this post and help David 93 SL2m reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
David 93 SL2m is offline   Reply With Quote
